Left side turn signal is very fast
MattyJoe
Yep, you heard it. When I flip up to right, everything is normal. When I click down to turn left, the turn signal flashes very quickly. Almost instantaneously and consistently. I just noticed this on my way home today. I noticed that the driverside front turn signal flashes very quickly. On the driverside rear, neither the turn signal nor the brake lamp work.
Whatcha think?
Thanks,
Matt
daniel3507
74
NE Oklahoma
2.3 EcoBoost
Start by checking the bulbs and fuses. if that doesnt work check the relay
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
Sounds like a simple burnt bulb to me.
Frank The Tank
43
South
Generally that's how you know your bulb burnt out........
Frank
Mtrhd0024
High Point/Thomasville NC
2.9
I think you solved your own problem in the first post! :)
When you have a bulb burn out, that side will flash twice as fast as normal... Replace the bulb and you should be good to go!
