leafs or springs for sas
RangerDan99
northeast, Ohio
4 liter V6
yeah i got pictures i will add them after work today
cdawall
5
Ellsworth AFB
4.0L V6
I would argue that the right leafs and the right setup will flex as much as needed if you're not doing some crazy buggy build.
I helped do a leaf spring build on a YJ a few years ago, it got a surprising amount of flex (took a little experimenting with spring packs to get it right, but it comes with the territory). We ended up doing a 3/4 elliptical in the rear while we were at it. It actually flexed better than my choptop that is running coils up front and leafs out the back.
Like you said they don't flex enough for a buggy. Hence what I am saying coils and coilovers are better. Leafs can flex well, but they cannot flex as well as a correctly setup coil/coilover. I have a great flexing set of rear leafs on my XJ has ton's of up and down travel, but it is nothing compared to the up and down travel the front has with its correctly set up 4 link.
That said.... for the OP, I would lean towards using coils or coilover/air shocks simply because the axle is most likely set up for coils and if you decided to go with something different, why convert the axle to leaf springs....
To go to coil overs would take just as much fab work as leafs. Going with a stock diameter coil is were the time saving/money savings is.
railman
December 2011 OTOTM Winner
12
Madisonville, KY
considering he has a 98+ IFS truck.....any SAS is gonna be alot of fab work....but in this case leaves would be easier....
plus, he never mentioned he was goin for a buggy anyways....
l8r, John
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Sounds to me that you need to post them pictures to see if maybe it is a Dana 30 and not a 44.
cdawall
5
Ellsworth AFB
4.0L V6
l8r, John
I have a 98+ IFS rig as well. I vote coils **** simplicity it will perform better :icon_hornsup:
Depends pretty easy to check if its 5 on 4.5" its a D30. 5 on 5" can be as well but they are a little more rare and just as strong as an EB D44.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
I have YJ leafs on my Ranger....they flex real good. I did add a leaf to help with the weight of the 4.0 and the A4LD. Hasn't sagged yet.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
If it is a Dana 30 from an early bronco it will be 5 on 5.5 not the 5 on 4.5.
cdawall
5
Ellsworth AFB
4.0L V6
I thought the Bronco was a D27 or 28 not a 30? The D30 I was referring to in my post was a JK D30 with 5-760x joints and the bigger ujoints.
4.0B2
151
Walls, MS
4.0 v6
the jk dana30 is not as strong as the eb44 in stock form.. but the aftermarket support for them is HUGE. the jk dana30 is a slightly glorified d30, period.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
If you go to Randy's Ring and Pinion and get into the Diff Wizard the only front axle for the 1976 Ford Bronco was a Dana 44. But that doesn't mean that it has not been changed to the 30.
cdawall
5
Ellsworth AFB
4.0L V6
So you are saying the eb d44 with its little bitty 5-260x joints crappy shafts is weaker than an axle known to be good with 35s pretty much stock and 37s with shafts a truss and reinforced C's?
The EB D44 is a terrible D44 in stock form it is not stronger than a 90s XJ axle. There is however a lot offered for them.
4.0B2
151
Walls, MS
4.0 v6
wait sorry. wrong axle. :thefinger::icon_rofl:
was thinking of 44 hp not eb...
No members online now.
