Ld f250
Ozwynn
200
Berrien Springs, MI
RE Interceptor
what automatic transmission came in the 99 F250 that looks like the F150?
other question....... how do I decode the vin so I don't have to keep asking?
TheTopher
176
Delaware
2.3
https://www.fleet.ford.com/maintenance/vin_tools/default.asp for the vin
Here's a little info on your 250.
some facts about the 250LD/F150 7700
- 7 Lug Rims -
- They have a larger frame then the F150
- Bigger Brakes
- 3:73 rear end from factory
- 4R100 Tranny
- Extra leaf in back
- Larger Torsion bars -
- Heavier towing capacity
- Weigh more -
- Larger rotors, I believe 13.5"
- HD shocks
- power steering cooler
- 4700 lbs rear axle
- HD rad, thicker
- HD alternator
- HD battery
- LT tires standard, load range D
- the tranny is the same as a F250 SD and the F350 SD
- 8,600 lbs towing
- 11,500 lbs GCVWR
- 7,700 lbs payload
Ozwynn
200
Berrien Springs, MI
RE Interceptor
thank you sir. I will bookmark that page on my phone aswell. I seen a couple real nice LD F250s ........ all things being equal they are about 2/3s the price if a Super Duty.
TheTopher
176
Delaware
2.3
No problem. I'm glad my insomnia was at least a little productive.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
apparently I can't view it on my phone........ is the F150 7700 the same rig as the F250 LD?
Seen one (F150 7700) in traffic today on my way back from drooling over 4 color back lit 55" LED 240hz full on 1080p 3d TVs at Best Buy and it appeared to be 7 lug.....
TheTopher
176
Delaware
2.3
Yea' the f150 7700 is the same as the LD250
When the super duty came out they just switched the name, I guess for less confusion.
17,953
SW Iowa
It was also when the '150 got a facelift, I always figured that was the reason.
Generally when I see one they have had the crap beat out of them.
They also have unique rims, I always wondered how Ford figured up that it was cheaper to design freakishly oddball rims for it than to throw another 4 studs/nuts on a truck and using off the shelf Super Duty rims. :icon_confused:
--weezl--
June 2011 OTOTM Winner
Law Enforcement
182
hell
yeah, how hard is it to get rims for these trucks now?
(i just saw one for the first time, f-150 with 7 lug counted it about 10 times to make sure i wasn't seeing things)
17,953
SW Iowa
There are a couple aftermarket options out there, dunno if it is the same pattern but there are still making 7 lug trucks.
