jimmyess333
- Aug 20, 2009
- 2
- Killeen TX
- Ford
- Engine Size
- 2.3
Hello all
I have an 07 2WD Ranger with the 7.5 rear and I'm preparing to replace a leaking pinion seal.
Although I haven't worked on one of these rears before I've been pretty successful in the past working on my own vehicles by taking my time and carefully following service manual procedures.
Over time and by experience I've learned that sometimes there are easier ways than what the manual says and sometimes it's a big mistake to deviate from what the manual says.
That brings me to my present job.
The manual lists 3 "special Ford tools" that I don't have, and the price of the tools alone are more than what a shop wants to do the job.
Pinion flange installer 205-002 $100
I'm not sure why I need this one if I can just tighten the flange nut to press on the flange.
Is the force required so great that is messes something up or does something bad to the crush spacer?
Maybe you can't get the nut on until the flange is pressed on first?
Is the spacing of the flange before torqueing the nut THAT important?
Is this a completely unnecesary tool that just costs a lot to discourage one from attempting the job themselves?
Flange holder 205-126 $110
Looks like something you can make for $5 but I can see how you would need SOMETHING to rotate the flange while checking for drag on the bearing.
Is there an alternate method like just torqueing the nut to a certain spec?
If I can just torque the nut why can't I just put the truck on the ground with the emergency brake on and the wheels chocked to hold it?
Seal installer 205-208 $92.09
I'm sure I can do the job without this one and at that price they should be ashamed.
A piece thick piece of wood with a hole in it, another piece of wood over that, and a hammer have always worked in the past.
Just make the hole in the wood the same size as the hole in the seal and keep it centered and level while you hit.
I've always found that going to the mechanic is admission of defeat and I'd still like to win this one if I can.
I'd like some input from people who have already done this job.
Are these tools even needed?
