knock or tick
jax4bangin
WESTMINSTER CA
2.3
wen the truck is idling there is a slight knocking noise i notice in the cab wit the radio off. its symilar to that of a diesel benz but not that loud.. shudd i be concerned? the truck has 40,000, i do regular oil changes with synthetic... cud it maybe be an exhaust manifold leak/crack?
jax4bangin
WESTMINSTER CA
2.3
come on no one has herd of this? it sounds like a sewing machine.. i just wanna know if i shudd be concerned
Tedybear
Firefighter
13
1994 Ford Bronc
5.8v8
Failing is easy. Everyone can do it.
Be concerned.
Any new or odd noises should be checked into.
Is this the Ranger listed in your information? A 2007 stands a fair chance of maybe getting the dealership to at least give it a listen. Also any TSB's might be useful if this is a known problem. (I know most are 3/36 for the maker covering any problem, but if this just hit the 40k mark? Some will still check into things considering it's still 'new')
S-
jax4bangin
WESTMINSTER CA
2.3
yea i have warrenty till 60k i just hate going to ford dealers they lagg so bad. just wanted to see if anyone elses duratec motor sounded like mine
wally
Michigan-rust belt
2.5L
I have a 98' 2.5 with the same sound. I've been told by many that it's possibly a sticky lifter. My motor has 145k on it though.
thewash
San Jacinto, Ca
3.0V6
Just a thought my 99 ranger was doing the same thing at about 80,000 miles. I found that if I filled it with unleaded it made that noise you described. When I filled it with the highest Supreme unleaded fuel it went away. When I changed back to Unleaded when gas was at $4.00 a gallon the noise came back. This may not work for you but it did for me and I wont cost you much. I recomend doing the swap on an almost empty tank to be sure the high octane has an effect faster.
jax4bangin
WESTMINSTER CA
2.3
huh i see, cud be detonation cause of low quality fuel.. i have been told thats its just the engine finaly breaking in
snakebit95
I have a brand new 09 that has about 1200 miles on it. It has a faint "dieseling" sound at idle. Did it the day I took ownership of it. Thought it was normal. The sound has not changed any since I brought it home either........so I am not too worried about it. Truck runs GREAT!! Can't get use to not stopping at every gas station either like I did with my 96 F150.
jax4bangin
WESTMINSTER CA
2.3
ok cool good to know its normal.. thanks!
