Key fob
777cigar007
South Bend, IN
Ford Ranger Edg
My key fob on my 2002 Ranger works fine but once the engine is running warming up in the winter, I can't use it to unlock the doors. What would cause this issue?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Do the lock/unlock buttons on the doors themselves still function normally?
777cigar007
South Bend, IN
Ford Ranger Edg
Yes everything else seems to be fine.
sheep herder
1,024
sheep pen
If it ain't broke, break it.
Maybe it's designed to not work when the ignition is on? I've never tried to use mine that way.
sheep herder
1,024
sheep pen
I checked mine this morning and it does work with the motor running. Don't know how much difference there is between '11 and '02 as far as the electrical system.
777cigar007
South Bend, IN
Ford Ranger Edg
Every Ford I have owned or family owned over the past 30 years has worked with the engine running if equipped with factory remote locks.
rumblecloud
1,126
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
There is some programmability with the key fob and how they work, but that is the extent of my knowledge. Maybe take a look at the Owner Manual page 109.
Just so I understand, you didn't mention it was a remote start, but I have to assume it is otherwise you would have to get in the truck to start it which means you would have to get out of the truck and lock the doors - but then you would have to have the key in your hand........and I'm confused which is not unusual at all:unsure:
If it is a remote start then all bets are off.
777cigar007
South Bend, IN
Ford Ranger Edg
No it is not a remote start key fob. You go out in the cold, start the truck, detach just the remote door lock key fob (quick detach setup), go back inside finish getting ready to leave 10 minutes or so and then go out to a somewhat warm truck. Its very nice when it's 20° or colder outside.
