Iv replaced the whole cooling system and still over heating HELP
Scuzzy883
Arizona
Dudes im at my witts end. Iv replaced everything in my cooling system i mean EVERYTHING and I'm still overheating. I just got do e replacing my heads cause of it I dont want to do it again
What am i missing??? Im not sure what else to do
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Details man, details!
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Did you replace the upper radiator hose?
sheep herder
1,024
sheep pen
If it ain't broke, break it.
Has PJ been peeing on it?
racsan
4,505
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
could you have a air pocket? Ive had that issue with 2.3’s before.
Scuzzy883
Arizona
So I replaced. Radiator, heater core, water pump, Tstat and housing, upper and lower rad hose and the hoses from heater core, fan abd clutch. Everything hahaha
Its a 91 4.0 4x4 with AC
Scuzzy883
Arizona
Any trick to getti g them out? If done the up hill burp
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
But seriously.
I've found evidence of casting residues in every cologne I've worked on, 2.9 and jy 4.0s. Did you flush and backflush your block?
Scuzzy883
Arizona
But seriously.
I poured water in the tstat housing till the block ran clean the frist time. Think I should get a flush treatment and do it again?
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Need pressure. Engine dead 12 hrs. Don't risk a head on a cologne. Thermal shock is bad for them. Garden hose at full tilt through the block and heater core both directions. Do till clear several times.
Take rad out flush upside down and right side up too.
Scuzzy883
Arizona
Copy that, I'll report back when I can
franklin2
1,775
Virginia
If you don't get it, write back in and answer some questions;
1. How do you know it's overheating? What are the symptoms? I hope you are not just going by the factory gauge. If you are, you should have other symptoms along with it. Or are you puking coolant? Any other symptoms as to why you think it's overheating?
2. When does it overheat? Only in town and not on the highway? Only on the highway and not in town?
