Is cutting the only way?
BrooksK
32
Texas
1996 and 2004
I am obsessed with birds.
I am redoing all of the interior in my '96 Ranger. I'm trying to get the seat belts out to replace them. This bolt has me at a stand still. The nut backed off about 2 threads and then the bolt just started spinning. I dismantled as much as I could, even took it out of the height adjustment track. Then I locked some vicegrips to the backside of the bolt since there's no head. I jammed a screwdriver in there for extra measure, and let it marinate under the heat gun on high heat. I still cannot get it to come loose, or even go back on any. It just keeps trying to spin the bolt. Is cutting the only way?
I looked on eBay for more height adjusters just to see. People are selling them. Without the nut. How? :ROFLMAO:
alwaysFlOoReD
5,129
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I would try a zip disc and grind as close the the bolt shank as possible. Even if you hit the threads a bit it wont compromise the strength of the bolt much.
Hopefully there is a better method...
BrooksK
32
Texas
1996 and 2004
Thanks. I found new OEM bolts and nuts online. I hope there is a better method too.
Roert42
5,012
Kintersville, PA
Ranger XLT
4.0 SOHC
Could try one of those but splitters. I’ve never tried one, so I don’t know how well they work, but there seems to be a million different designs out there.
70528
vigness
37
Princeton, KS
Ford Ranger FX4
The splitters don't work on flange nuts, and not up close either. Best option is to grind / cut one edge down, then the other and split it manually. Inwouldn't be all that concerned about the adjuster. The stud is supposed to be fixed to the slider so you are looking at replaceing that part anyway. I would only try and save the stud if you think you can spot weld the stud from turning once you have it apart. Have to weigh the cost of a new / used slider vs the extra time it wall take to salvage the one you have.
97RangerXLT
TRS 25th Anniversary
3,979
Fishers, IN
2"
31"
Also try some heat from a torch,, not a heat gun.. My guess is Ford put the permanent locktite on it at the factory.
If that doesn't work, I also say use a nut Cracker/ splitter.
AJ
Roert42
5,012
Kintersville, PA
Ranger XLT
4.0 SOHC
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Have a small GrindingWheel that fits in my power drill chuck;
I'd grind away enough of the nut to get it off, being careful not to booger up the bolt.
rumblecloud
1,133
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
Do you own a dremel?
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
I have a swiss army knife that works. Its called a cutoff wheel. I would start with the small size called dremel, otherwise go with the 4 1/2" angle grinder one.
Jazzer
457
Indianapolis
I’d drill a hole in the bolt, tap in a slightly oversize torx bit, hold it with a wrench and undo the nut with another wrench.
-Jazzer
BrooksK
32
Texas
1996 and 2004
This is what I was thinking. I don't think that I could spot weld it or use a torch. The bolt passes through a piece of plastic which would melt. I could cut the nut off and replace both the bolt and stud, or find someone parting out a ranger and see about getting the adjusters off of it. Currently searching for Ranger part outs.
Thank you all for the help.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Or you can pull out on it as you turn the nut....
Or....make the nut up slightly..and the the Dremel or cut off wheel....make just a small slot...to hold with a screwdriver...and back out with wrench.
vigness
37
Princeton, KS
Ford Ranger FX4
To bad you're not closer to Kansas CIty, I have to 98's I'm in the process of parting / junking out. One is a 4 door. Should be the same part. I'll take a look later. Which side?
BrooksK
32
Texas
1996 and 2004
:sneaky: Both.
