05MountainGoat
- Sep 4, 2023
- Reaction score
- 14
- Location
- Vancouver Island
- Make / Model
- Edge
- Engine Type
- 3.0 V6
- Engine Size
- Vulcan V6 3.0
- Automatic
- 2WD / 4WD
- 2WD
- Total Lift
- 1.5" T-bar Crank, Aftermarket Forged Keys
- Tire Size
- 32"
From a fellow 3.slow driver with NGK plugs and wires...Alrighty folks!
Based on everyone's feedback, it seems the hotter coil isn't going to be necessary, even with gapped plugs. I've put a bit of non-conductive epoxy on the damaged tower of the stock coil, and added a little tiny bit of dielectric grease to keep it from grounding out, it shouldn't be an issue going forward since the coil is otherwise working just fine. You've all recommended some great stuff for improving efficiency, some of which has already been done, others are in the works, and some I hadn't really considered, so thank you as always!
But in the game of maximum efficiency, every single percent counts.
Here's the plan with what we have on hand:
I'm going to be installing the NGK Iridium IX plugs gapped to 0.065, and try to index them to the best of my ability. Frankly I've never actually indexed my plugs, but hey, it's probably a good idea when we're going for even the tiniest of gains (thanks @Uncle Gump).
When it comes to wires here, we've got 3 options, and I'm going to measure the resistance on all of them with a multimeter to see which wires work best:
When it comes to the coil: Given the fact that I live in snow 6 months of the year and I don't want to short anything out, I will be replacing the coil pack at some point soon, I may just grab a motorcraft unit from the junkyard given that new ones cost around 90-120$, give or take some shipping and handling. Or if I'm having trouble with the now gapped plugs, ordering the upgraded MSD unit.
- Stock wires, I think they're motorcraft, but frankly they're still in the truck and I haven't had a chance to read what's on em.
- Standard Motor Product, 8MM Standard wires, (for some reason I thought I had bought NGK wires)
- A set of unused JDMSpeed 10.5MM wires that I forgot I had, I may need to splice on different plugs from the original wires, or the standard set if they don't fit the coil's towers.
Testing and measurement: Aside from testing the resistance on the wires, I'm not sure how best to go about measuring any efficiency upgrades short of subjective observations.
Fuel economy data is great, but affected by so many other factors, it'll be difficult to figure out if in fact we're getting more efficiency. Unfortunately I don't have a dyno laying around (or within 400kms of where I live) to help me out on this one.
If you have any ideas on how I can gather some data, let me know!
I bought my truck about 20,000kms ago, decided to do plugs/wires last month at 290k km. NGKs plugs and wires were already equipped on the truck. Reading these forums, I opted to use NGK Double Platinum "Laser." Laser just means there's a very tiny nipple on the outer prong facing towards the center electrode- there were six available locally which was the deciding factor in purchasing them. They were pregapped to 0.046, and within spec. When I pulled the old plugs, I found the center electrodes on the old drivers side plugs were worn down past the rim of the concave area they protrude from. Fuel Economy has improved with the new plugs/wires- to an extent. Theres definitely more power available, and more power is potentially better fuel economy. Potentially. Regular gas is 89 octane locally, I no longer have to run 91 to avoid a bad time at high RPMs. Definitely a learning experience. Super nice to get about 500km to the tank 70/30 highway/hill infested town- was 350km to a tank at the same average before new plugs/wires.
The moral of the story is, make sure your NGK plugs are Double iridium, Double Platinum, whatever so long as both electrodes are coated in that fancy material. There's lots of posts here which explain the how and why behind this more articulately than I could.
