iac valve question for SC
Snurfer
snowland, Or
running an m62 xterra supercharger on my 4.0. building the intake plenum. my question is the thunderbird throttlebody has an integrated iac valve... so would i be able to use the TB off of the tbird instead of having to make a bracket for my ranger iac valve to attach to on the intake plenum?
98blownranger
wi
ranger
I have not worked with that tbody but it you can wire it up yes you can. or try the one for the 5.0 fox body stangs. they have the IAC on the tbody also
anupaum
I use the Mustang throttle body and IAC valve without trouble. It should work for you!
AKBroncoII
The IAC looks the same from my 4.0 to the 3.8 M90. I'm just going to use the tbird TB with the 4.0 IAC. Going to try to mount my M90 like it is on the Tbird but I might end up mounting it like the M62 on yours.
anupaum
If you're referring to ME, my M 90 is mounted to the side of the engine. I'm using a Mustang throttle body and IAC valve. It wires the same way as the stock one for the Ranger.
Snurfer
snowland, Or
perfect. im glad that the IAC valves match up. thanks for everyones help!! i appreciate it.
