How to: Install aftermarket speakers
korey89
This is a how to on a 2002 four door extended cab. It is pretty straight forward.
We are going to start with the front panels first
There are three screws that must first be removed
Now put the window down, it makes it a little easier
Now we need to remove the handle piece, it pulls straight out
With that off there is one more screw to remove behind it
Here are the four screws we removed
Now pull the panel up and out
With the panel out of the way you can leave the handle piece dangling, no need to disconnect the connectors.
Remove the old speaker, it is held on by four self tapping screws
My speakers came with single sided sticky foam, this works great and eliminates and rattles that you would get from a metal to metal mounting. If yours came with it too now is the time to install it.
This speakers also come with mini crossovers on them. Cut the old connectors off the wires and strip the wires. Then loosen the phillips head screws in the crossover, places the wires in the holes (wire with no stripe is positive, wire with black stripe is negative), then tighten down the screws to secure the wires
You cant just leave the crossover hanging, secure it to the inside of the door on a flat spot with double sided tape
Install the four screws to secure the speaker
These speakers feature a very cool adjustable angle tweeter that has a -3dB gain button on them. Sit in the truck with the door closed and music on and play with them until you find how you like it. I liked the tweeter angled towards me with the button not pressed in.
Now you've got a great sounding from speaker!
Put the door panel back on in the reverse order you took it off
Now repeat with the other front panel and the fronts are done.
Time for the back doors.
There are no screws holding this on, just push type plastic pin things. So just pull it towards you.
I did not want to mess with removing the seatbelt or anything so with a little maneuvering of the panel you can get it to hang out of the way
Heres the old speaker
It is secured the same way, remove the four screws
Pull the speaker out, and install the single sided sticky foam
Hook it up the same way you did the fronts and secure the crossover the same way with double sided tape inside the door. Then secure the speaker.
I already adjusted my tweeter, here is a closer up picture
This part was a little annoying so I couldn't get any pictures. Make sure you don't have any of those little push pins still stuck in the door, then light them up with the holes in the door and work your way around the panel pushing them in. If you don't do this you will have a loose panel that rattles under any bass from the speakers.
Door panel secured
Now admire the pretty new speakers and the great sound they produce!
Bob Ayers
16
Durham, NC
A suggestion, you can remove the connector from the OEM speaker, and attach it to upgraded speakers. You have to shave some plastic, and be a little creative with a soldering iron. By doing this, you can use the connectors
on the wiring harness, and you will be guaranteed the phasing will be correct:
korey89
That is a good idea, but is not possible on these speakers since they feature a mini crossover that your Pioneers do not.
Bob Ayers
16
Durham, NC
The crossover is a built-in L-C network on the Pioneers. Most speaker upgrades will have the solder lug type of connector that the OEM connector
can be soldered to.
cr_the_machinist
Dexter, Michigan
4.0L OHV
Yeah, thats what I did with mine Bob. Made it 2 times easier and it looks more professional. Those connectors are pretty slick too.
