How much weight is enough?
Lefty
1,854
Saint Paul, MN
Ranger Edge
Just curious. How much sand or gravel do you put in the bed during the winter months? And No! You good ole boys south of the Mason-Dixon need not answer!
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,506
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I don't use any.
gaz
671
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
500lbs, plus or minus 50lbs.
ericbphoto
Overlander in development
16,658
Wellford, SC
3.0L
6"
But, but, but...
Blmpkn
Toilet enthusiast
6,370
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I used to put 200 or so in the back of my 2wds. Don't bother now.
Uncle Gump
Token Old Guy
13,506
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Just the factory traction lock differential.
But yes... 4wd. My cap also adds weight and my spare weighs 70lbs...
85_Ranger4x4
17,911
SW Iowa
4wd and send it.
19Walt93
4,483
Canaan,NH
351
3"
235/55R16
I've never added weight to a vehicle- other than when I get into it. After my father died in 1989, I got his 83 Ranger, 2wd, shortbox, 2.0, 4 speed- thinking I'd do the valve job it needed, run it a while to make sure it was good to go and flip it. I drove it through 6 winters before my kids got bigger and couldn't both fit in it. I thought about adding weight but never did. With 3.08's and a 2.0 it would hardly spin a tire- only one, no limited slip.
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
I don't add "weight" as in steel or such. However, at times I have been seen with added snow packed into the box for weight. being that as it warms up, the snow melts out and there is no need to take said steel back out again.
Vindictus
330
NewBrunswick Canada
ReMan 4.0 SOHC
Don't keep weight in bed of truck. Don't need it 2wd rocks winter.
Saw a truck rear end a transport on the highway, truck had cinder blocks for weight.
They slid forward went through the cab landing in the engine bay. Engine was pushed under the tailor.
Second worst accident I've seen
lil_Blue_Ford
6,185
Butler, PA, USSA
4.9L
I used to run 2-300# in my 2wd Ranger. Kinda depended on tires, I played with weight a lot with it trying to find a good compromise that didn’t take up all my bed space.
My 4x4s I usually don’t bother. First few winters with my F-150 I put a couple hundred pounds in the bed, used tube sand from Home Depot, but they often froze and either stuck to the bed or would slide around slamming into stuff. And they were always in the way. Once I put my first set of Mastercraft Courser CT tires on and a locker, between that and having a ladder rack with side boxes, weight isn’t needed except when I have the plow on (even then I’ve made do without weight).
Blmpkn
Toilet enthusiast
6,370
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
