How do I unbolt the torqu converter???
Psychopete
29
FW, IN
normally you pull the bottom of the dust cover from the trans, and access the torque converter nuts from there. There will probably be 4 nuts. Turn the engine clockwise to get to the next one until they are all removed.
thisfords4u
Wimer, Oregon
2.9,2.9,4.0,4.0
Or remove starter and access through starter hole.
Swepper
Miami, OK
2.9
Did one on s10 itwas a sob dont knw if same as bronco but most converters are same
Mac
183
C. Wisconsin
2000
199
Too much compression? Pull the spark plugs might help.
Dave
Swepper
Miami, OK
2.9
Make sure its not in gear also
Swepper
Miami, OK
2.9
From expeirence also get a set of self ratcheting wrenchs. If u dont already have any.I couldnt geta 3/8 ratchet in there
Swepper
Miami, OK
2.9
1984broncoduce
olive branch mississippi
2.8
hey guys, a little update, my bud die and I were working on it to day during class ( i blew the motor and I'm rebuilding it in my automotive class) and he accidentally removes the drain plug, so we had to wait for it to drain and we ran out of time, i did however turn the motor over with a breaker bar on the nut on the front of the motor and he said the torque converter moved a little, i believe i turn it clockwise correct? and how hard should it be to turn?
Psychopete
29
FW, IN
lol should have just put the plug back in. it will be relatively tough with the plugs in on compression. and the engine being "blown" probably isn't helping either.
1984broncoduce
2.8
haha yea i probably just put the plug back in, but we just decided that it needed some new trans fluid
Swepper
Miami, OK
2.9
How did motor blow if u snapped a rod its probably not goin to turn. Sounds like u might have to pull the tranny
