Help me not pressure wash the engine
JavaG66
5
South Carolina
So I just got this 2000 4x4 Ranger with 198k miles on it. I don’t think it’s ever, never been washed and it’s bugging me. Orange mud on top of the black plastic manifold & black soot on top of that. How involved is it to remove the wiring harnesses and re-install them without taking the time to label it all (yes, I’m lazy). And besides wires and brittle vacuum lines, what are other reasons I shouldn’t do this?
ericbphoto
Overlander in development
16,696
Wellford, SC
3.0L
6"
I would not remove the wiring harness. You may end up forcing dirt and contaminants into open connectors. Then you end up with bad connections.
I would disconnect the battery. Cover anything you don't want getting wet. Then use an engine degreaser. Follow the directions. Use rags and small brushes to clean nooks and crannies. And rinse with a regular garden hose. Blow excess water out with compressed air or leaf blower. I personally think it's too easy to damage something in there with the pressure washer.
JavaG66
5
South Carolina
That sounds tedious, but if I’m honest with myself, it’s probably less involved than stripping the engine of anything that I don’t want to get water into.
Good counsel.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,726
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
You can use a garden hose with a nozzle for the wetting and rinsing so you can get a bit more force but don’t go whole hog. Even full stream with a garden hose can cause problems. Yes, it will be tedious.
The benefit of a clean engine is better cooling and better ability to see any leaks that might be there.
Not to mention working on a oil, grease, and dirt coated engine is not fun in anyone’s book.
JavaG66
5
South Carolina
Agreed. Even though I like fixing things, that & one mosquito will cause me to indefinitely postpone the work.
sgtsandman
Ham Radio Operator
12,726
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
The mosquito will wait until you are covered in grim before they show up. It is the order of things.
19Walt93
4,488
Canaan,NH
351
3"
235/55R16
Use a cleaner called either Pink Stuff, Awesome Pink, or Incredible Pink-depending where I buy it- that I buy in a gallon jug and dump into a spray bottle. I spray it on everything grimy and rinse it off with my hose, then blow the bulk of the water off with compressed air, close the hood and wash the rest of the vehicle because the Pink will lift the wax off the paint. Then I run the engine till it's warm to evaporate the rest of it. Pink works great on white letter tires, too. The fumes are pretty strong so I only use it outside.
Junk Collector
Truck of Month
4,849
Rapid City SD
I pressure wash under the hood all the time. Other than getting a distributor cap wet and causing a no start I have had zero issues and I certainly wouldn't be worried about a 2000... engine bay waterproofing has come a long ways since the carburetor era. I'd probably try to stay away from the fuse box but otherwise go to town.
Degreaser spray is nice, I like to buy a gallon of citrus degreaser and cut it 50/50 with water and apply with a pesticide sprayer. It's cheaper and I think it works better than the aerosol degreaser spray.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,521
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I typically power wash under the hood too. I'm just careful around stuff I should be.
