Help Fixing This ???
96JackedMazda
Mazda
Need help with XP
Corrupt Files/Quick time
I tried running the "chkdsk" but it does nothing
Please how can i fix these corrupt file there are a couple of them
Thank you
Justin
fleck
Florida
Mazda
Go to My Computer, right click on C drive, go to Properties (bottom), in here go to the Tools tab, click Check Now and make sure both check boxes are selected, hit Start, it should say 'Schedule disk check'. This will allow you to reboot and Windows will then perform an actual chkdsk that'll do stuff before the OS loads. Good luck.
97RangerXLT
TRS 25th Anniversary
3,967
Fishers, IN
2"
31"
x2.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
If the check disk doesn't find it, did you try remove & reinstall (R&R)?
I usually just remove a program and then run the chkdsk and/or defrag..then reinstall the application...
Would also be a good time to check the volume for free space...files corrupt much easier or are harder to find when the disk is over 50% full...
96JackedMazda
Mazda
Thank You "FLECK" but it tells me that it was unable to check disk
fleck
Florida
Mazda
superdave1984
24
KY
You probably have a bad sector on your hard drive. Remove the offending progem completely including registry entries then run chkdsk again. If you can't run it like has been mentioned, pop in the XP disk and boot to it. Go to the recovery console and run it there.
96JackedMazda
Mazda
Will not let me remove quicktime under the program files
it is in the program file that is corrupt, say my windows live email is corrupt as well
fleck
Florida
Mazda
Well, did you try it again and see if 'schedule disk check' came up? That's when you say yes and reboot and Windows runs chkdsk.
If that doesn't work I think you might just have a virus.
warrior24
Surprise, AZ
virus 90% probability.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
