Lonewolf
- Sep 22, 2009
- Reaction score
- 0
- Make / Model
- ranger
- Automatic
anyway my questions are pretty basic if you can help thanks.
Should I fill the torque converter with fluid and put the torque converter on the trans before i stab it back in ? then bolt it to the flex plate
should I buy a new torque convertor ?
is there anything special to do when bolting the pump back up ? I am being careful with the little O-rings on the bolts and re-using the gasket which stayed in place and looks clean
can I put the 3.0 final drive splines and pump still bolted to the bell housing right in the other trans ? everything seems to MIC out identicle
98 Ranger 4x4 3.0 4r44e trans, burnt rear one way clutch. 140,000 miles
Trans shop est . $2000 ++++++ (you know the story)
truck is only worth $3,000
I decided to spin the roulette wheel for $200 and found a crash yanked 5r55e complete with Transfer case from a 2002 4x4 4.0. The guy said it had 40,000 when he rolled it and it sat in the garage 4 years.
My odds may be good because it looks like new inside the pan and all the lines and wires were snipped sort of confirming it was a crash yank out and the guy seemed pretty honest
I welded up a rig for my floor jack to hold the trans and got the trans out and I am in the process of swapping bell housings right now. Took me about 8-10 hours to get this far.
I got a new front seal , is the pump hard to get out of the bell housing to change the seal ?
It looks like another PITA
I read on a ford ranger website that I can swap bell housings and everything fits right up
everything looks identicle externally from the plugs to the linkages
I got a shop manual and will look up the bolt torque
I gotta lot of respect for you mechanics, this is a very difficult job and my first auto trans , I've done about a dozens clutches and even repaired stick shift trans (pre-90's , did a clutch in a Kenworth all by myself once, but the auto trans is strange and these newr trucks are whacky to work on.
Wish I had some help !
I'll buy the beer
I gotta lot of respect for you mechanics, this is a very difficult job for me and my first auto trans , I've done about a dozens clutches and even repaired stick shift trans (pre-90's , did a clutch in a Kenworth all by myself once, but the auto trans is strange and these newr trucks are whacky to work on.
I'll buy the beer
I'll buy the beer
I'll buy the beer
