heater blower not working
Raw16057
Baden PA
Hi, i have a 94 B4000 ext cab 4.0 5 speed 4x4 with air and my heater blower is about gone. Anyone here have an extra one they would like to sell? PM me.
02_B4000_4x4
Mazda
I just bought a 02 B4000 4x4 Automatic and the number 2 fuse in the fuse box controls the O/D, Daytime Running Lights, Blower motor, Reverse Lights, the Air Bags, and i think there is one more. I am trying to look for help too. Mine lasts for about 15 minutes blower motor on full before it blows the fuse. I am looking for any advice from anyone.
sparkola
Mazda
Do they only work when the fan speed selector is on high? Its the resistor pack located in the blower motor housing under the hood. costs about 30 bucks to replace and about 30 mins with the right small sockets/nut drivers and some patience.
Raw16057
Baden PA
blower motor conclusion
hello, got it fixed. went to the junkyard and bought another motor that had good brushes, put it on and now it works like new.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
If you're blowing fuses you need to check back on any recently installed parts...it's probably not the heater fan that is blowing the fuse, but something else on the same circuit...if you happen to have installed a new stereo or modified any accessories that would be the place to start...
You may also have a bad ground on something...check under the hood for loose connections...
:icon_thumby:
Cool...I did mine last summer...nice to know it's such an easy fix...and that you can still buy new blowers if needed...and also that the parts are interchangeable from the 80s right up to the late 90s on these trucks...
02_B4000_4x4
Mazda
I found the problem. Its an auto and where the wires for the O/D leave the shifter into the coloum, the rubber coating on the outside rubbed off leaving the wires exposed, and when ever I shifted, it would rub against the metal on the coloum causing it to ground out. Thanks for the info though.
