Heads up for all 92-04 Ranger owners.
LittleBigFoot
5
Denver Colorado
Mostly Ford.
Building a 408w
I just got a recall notice from Ford.
"Ford casnnot be cinfident that over many years in service, the type of Speed Control Deactivation Switch (SCDS) equipped on your vehicle will not leak, posing the risk of an underhood fire. This condition may occur either when the vehicle is parked or when it is being operated, even if the speed control is not in use."
Heads up, I guess...
pimtool
prosperity,SC
I think they had the same problem with some full size f 150 and broncos. Met a guy his 96 bronco burned up while it was parked in his driveway. Pretty scarry.
Wicked_Sludge
43
Westport, WA
3-point-GO
this is a very easy problem to avoid. the deactivation switch is on the end of the brake master cylinder, in clear view. simply pop your hood occasionally (i suggest at least every time you fuel up) and check the switch for indication of a leak. if it stays dry, no worries. if it starts leaking replace it immediately. FYI, ford "fix" appears to be just a fusible link that plugs in between the switch and wiring harness.
stegomon
20
auburn/minot maine
fords and only
ya i got a notice for my bronco...it was leeking one time...went to a junk yard and got a booster with out cruise....who needs that crap any way...that is what a brick is for :):beer:
ranger_veazey
lamarque ,tx
yes i heard about that about 6 months ago... its from your cruse control
warhawk
Grand Haven, Mi
4.0L SOHC
I received the same recall notice in the mail today. I'm planning on getting my truck into a dealership asap. I almost have one payment left on it, all I need now is for it burn itself down.
LittleBigFoot
5
Denver Colorado
Mostly Ford.
Building a 408w
Yeah, the dealerships are suppose to fix it at no cost for parts and labor. I just figured I should post this for those who havn't gotten the notice yet
LearjetMinako
12
Moore, OK
2.3L 140ci
I suppose this recall will only be sent to those that still have their trucks under warranty.
Even not, I still don't quilify. Vaccum cruise control (Genuine Ford aftermarket add-on), it de-activites by the brake light signal, clutch switch, and vaccum release on the brake pedal.
warhawk
Grand Haven, Mi
4.0L SOHC
Went in for the recall today, took about 5 minutes. They just put in a fuse-able link where the wiring harness plugs into the brake reservoir. Aren't recalls sent to everyone Ford has on record as owning the vehicles in question? I know it's not just for trucks under warranty, mine sure isn't.
17,835
SW Iowa
No they go back regardless of warrenty, my '02 was just out before I got my notice in September to have it disconnected until parts came in first during November, then February.
I don't think it goes back 1992 Rangers, just 1998.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
I got one for my 2002 F-250, and it was not anywhere near warranty status.
The fix, looks half assed at best. Now I have a huge wiring harness zip tied upon itself.
Jeepman401
CT
Its the same fix they have been using for years now, and they still havent bothered to make something that dosent look like shit.
