heads, lifters, pushrods, shaft style rocker arms
C130MARINE
ft worth Texas
1991 Ranger STX
Hello Gents,
Okay here is my situation. I have a 91 STX 4x4 with 4.0 OHV truck has sat a 1 1/2 yrs now. Parked it because lower intake was leaking. Building a nasty 347 swap. Okay well now i need this truck to be my daily for a few months. I tear her down only to find collapsed intake lifter on number 4. Great, so now i have to pull the heads (all orig motor, never has been torn into) I also see there is wear on pushrods. Okay so my plans are to order 95tm heads(yes bump the compression, Im well aware). Does anyone make the spacers that go inbetween the rockers anymore? I saw our stock ratio is 1.5 does anyone make a 1.6? where is best place to get rockers and pushrods and lifters? Yes, i dont want to put a ton of money in the 4.0 but i dont want to buy china crap and have it fail. All the posts i find are from 2010, 2009, 2005 and older. I really want to go with the 422 cam as well, and i will justify 300 bucks, since i have to buy lifters anyway, but then i read i def will need diff springs and have to get head machined to hold the larger diameter?
so where is the best place to get rockers? and diff ratios avail if i were to keep the stock cam?
spacers for the rockers? any memebers know where to buy a set or who has them?
if i go with 422 cam, where can i get the recommended longer pushrods?
brands of lifters to stay away from? or the brand i should buy?
biggest oversized valve to fit in our heads is 1.8 and 1.4 (from what i have read) was wondering if i should get bare castings and buy valves and springs seperately. does anyone have a clue if any company i could call and give the application and they will know what to make as far as the valves?
Gents i appologize, but i need to get a plan together quick. all assistance/guidance/comments are welcomed.
Thank you,
Dale
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
Hi I did the 410 cam swap a few years back. The push rods came from a shop in Oregon with roller lifters i did replace them, however that was just a matter of doing. probally they didnt need to be done. why go the 422, and not the 410? from what you said all the head stuff will probaly be work done at a custom head shop, i don't think there is much stuff after market for the heads/head work. not much but i tried to help ya.
