Headliner wet across front.
dvdswan
1,777
Seattle, WA
Ranger XLT 2WD
Been there... Done that....
dvdswan
1,777
Seattle, WA
Ranger XLT 2WD
So after a night of rain, I went and checked the cab for water intrusion. It appears the rear is still leaking. So, I guess I'm taking the topper off to get access to the cargo light to see if its cracked or whatever. I will keep you guys updated.
dvdswan
1,777
Seattle, WA
Ranger XLT 2WD
OK, so I found the culprit...
55951
Hole large enough so the screw would not grab. PO obviously tried to seal it with some kind of sealant and failed IMO. I cleaned up the little rust spot and treated it. Cleaned up the gasket and light assembly and resealed them together. Then used some clips I had so the screws would grab and tighten the light assembly to the cab of the truck.
PO attempt to seal the screws.
55953
I used 2 of these clips (one for each screw). The gasket is plenty thick to cover the whole clip.
55954
Before removal...
55955
Now we will see if there are any leaks tomorrow or later today as the rain has started up again.
dvdswan
1,777
Seattle, WA
Ranger XLT 2WD
So I was able to pull the slider out today. Found most of the drains were clogged as well as the frame drains were clogged too.
56250
56251
56252
Ended up using window cleaner on the gasket, then cleaning out the channels with a rag and screwdriver.
56253
56254
Cleaned out the frame channel as well. You can see the run off channel on the bottom that goes to the drains.
56255
56256
Cleaned all the drain holes and the channel and ended up with this crud... there is still a lot on the rag too.
56257
Next was the slider frame and cleaning out its drains...
56258
popped out the seal for the slider when its closed...
56259
56260
Cleaned out all the crud on both sides.. and reinstalled...
56261
Pulled the pin for the window stopper in the center and cleaned the felt off...
56262
56263
Reinstall the gasket...
56264
Just make sure you install the gasket the correct way. I ended up putting the inside facing out... and sadly didn't notice until I had it completely installed. Pulled it back out and reinstall the gasket the correct way and back in the truck.
56265
Before installing the window I check the body for any corrosion which there wasn't any. Cleaned the matting surface then installed the window.
56267
56268
I did run some silicon on the seams at the top corners of the cab, then ran silicon on any seams that had gaps...
56269
While the best way to reinstall the slider is with 1/8"-3/16" cord, I could not find mine. So I had to pull the gasket back in with screwdriver. Not the ideal way but it can be done. You just need to be careful not the tear or puncture the gasket. You see here how the latch is on the outside. Oops!
56270
And proof that I did catch it and fix it. LOL
56271
I did a water test. Good news - slider and seal not leaking any more. Bad news - found a new drip. Same area but coming from between the 2 panels below the rear window. Its not the window or seal, its not the cargo light. So tomorrow I start using tape to find it. You can see the drip on the rib next the carpet edge. Its just enough to call it a day and attack it tomorrow.
56272
fixizin
FoMoCo is forcing me to buy a 'yota
110
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
Great detective work and solid repairs... OTOH, I'll never again wish I had a rear slider, lol...
Kudos to Uncle Gump for the Ebay link to the 3rd brake light gasket... having just passed it's 22nd birthday, and being in rainy So-Fla, I'm sure I'll be needing one sooner rather than later.
Blue 92
54
Pacific Northwest
Ranger Supercab
Hey @dvdswan , thanks for the detailed post. I knew I had a water incursion problem and have not driven in the rain for a while. Washed the truck yesterday and unfortunately have the trifecta - wet liner in both upper front corners and rear center. Have a big chip in the windshield so will probably just have the glass replaced, and need to look for stripped screws in the rear. Did you just use regular clear kitchen type silicone to seal the light?
dvdswan
1,777
Seattle, WA
Ranger XLT 2WD
No, there is actual silicon for windshields. It's clear. Comes in a tube about the size of gasket sealer.
franklin2
1,099
Virginia
If you want to use hardware store silicone, make sure you get the 100% silicone with the 50 year warranty. Most kitchen and bath sealers will not work good outside in the weather.
You can try the shotgun approach and just seal the areas he did. But if it doesn't work, you will have to do with both he and I did, and pull a lot of the interior out, and drive it that way while you investigate where the water is coming from.
Blue 92
54
Pacific Northwest
Ranger Supercab
The wet spots in the front were tight to the upper corners after a washing, so if not the window seal or god forbid corrosion in the upper corners where else would it be coming from? It's not like I am chasing (yet) a wet carpet.
alwaysFlOoReD
Forum Moderator
3,693
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Gutter seals. (Caulking)
dvdswan
1,777
Seattle, WA
Ranger XLT 2WD
Just as @alwaysFlOoReD said... just the little cracks in the body caulking allows water in. You can see the cracks in the paint.
61722
61723
franklin2
1,099
Virginia
Yep, the factory just spot welded the top to the gutters, and then smeared sealer in there. That sealer getting hard and cracking is one of the main reasons the older large trucks had rusted out cab corners. Don't know about the Rangers, but they seem to be put together the same was as the full size trucks.
Blue 92
54
Pacific Northwest
Ranger Supercab
Yep - checked the gutter seals and there are thin cracks on both sides in the middle and right down into the windshield. Is it possible to seal the cracks without pulling the windshield, or do the cracks/seams run under the glass in a way that the liquid gasket holding in the window would not seal that portion of the seam?
dvdswan
1,777
Seattle, WA
Ranger XLT 2WD
You can remove the windshield trim to get to the seams. If the windshield has been replaced you might as well run a thin coat around the edge of the glass to windshield sealer too. I had leaks there as well.
Blue 92
54
Pacific Northwest
Ranger Supercab
@dvdswan , you mention sealing around your windshield to stop the leaks - did you also have to do something with the cracked areas at the ends of the gutters? I've been living with not driving the truck in the rain, but son just bought a house and I need to be out in the weather
