Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
30 ft-lb. Give it a little soft tug on the ratchet, but don't overdo it, if you used enough RTV (I use a 1/4" bead), some should ooze around the edges a bit.Will I need to torque down the cover to spec since im using silicone rather then a gasket?
There is no gasket, ford used RTV silicone from the factory. Just tighten them down snug by hand with a ratchet.Will I need to torque down the cover to spec since im using silicone rather then a gasket?
