- Sep 19, 2021
- 0
- NWA
- Ford Ranger FX4
Hello everyone. I recently acquired a 2007 Ranger FX4. It has 165k miles and runs like a top but the suspension is shot. I'd like to replace all of the "non-fixed" suspension components. I am not sure how else to phrase it. Shocks, coils, leaf springs, bushings, etc. Do I need to replace controls arms if they aren't bent (I had a Silverado that pressed in bushings and had to replace the whole control arm). I have searched, to no avail, for full STOCK suspension replacement kit. Do any of you know of anyone that sells everything as one? If I have to Frankenstein it, can you help on what I need other than shocks and leaf springs? Even if bushings pass the shake test (just grabbing what its attached to and see if there is play), I'd like to replace it while everything is torn apart since it is all stock. I do not want to add a lift. I should add, the truck does sit level so it may have the t-bar crank but not sure. Any help greatly appreciated.
