Front Suspension Rebuild
xeris
Mazda
At 236000 mi. the creaking, thumping and squeaking needs to come to an end. Long overdue for a rebuild
Slowly getting ready to start gathering parts. The truck has lived it's entire life in AZ and the frame and suspension components are for the most part rust free. I have a ball joint press and have done this type of job before on other vehicles. Also have the torsion bar tool and have read up on how to remove them. I understand that it's more time to replace the bushings and ball joints in the original arms than replacing with complete parts. For me, extra time spent is not an issue, especially if it reduces cost.
I'm of the understanding that I will need camber/caster eccentric hardware to properly complete the rebuild.
A couple of questions that I have are.
Is there any advantage/disadvantage using the single or two piece (right side) upper control arm? Assuming I go with complete aftermarket arms.
Are the after market control arms, both upper and lower with ball joints and bushings, good enough quality? That is, equal to OEM parts.
Any helpful tips would be appreciated.
Thanks in advanced
Dave
don4331
1,355
Calgary, AB
5.3
The advantage of the 2 piece arm is you can adjust caster; with one piece you are stuck with how Ford welded up the chassis. As the left (driver's) side didn't have any adjustability, Ford engineers didn't consider it critcal.
The camber adjusters are on the upper control arm bolts. you should be able to reuse the existing ones. (I mark the existing ones position and use that as starting point after replacement.
I can't comment on quality of aftermarket arms, I've just replaced bushings/ball joints.
When I did mine, I had truck up on stands, then used hydraulic jack to lift lower a-arm. Then I disconnect the upper ball joint; when I lower the jack, pressure comes off the torsion bar and eveything falls apart.
Reassembly is reverse process.​
pjtoledo
3,006
Toledo Ohio
Fords
3.0 2.3
the 2 piece passenger side upper control arm is replaced with a single piece.
caster can be adjusted by rotating the camber cams in opposite directions.
xeris
Mazda
Thank you both, don4331 and pjtoledo for the replies. Confirms the info I had researched.
Now to fork over some dough.
mikkelstuff
470
Brighton, CO
3.0L
My experience, Moog still make quality parts. I used Moog ball joints and upper control arms for my 2002 4WD Ranger and have been pleased.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,815
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The Mevotech TRX line is a decent brand to work with as well. Don’t get the non-TRX, blue booted parts. Those are junk.
