jburden78
- May 11, 2011
- 0
- St Catharines, Ontario
- Ford
- Engine Size
- 4.0L
Hey, I've been reading posts and asking around for a while now about why there is sometimes a very noticeable vibration in the front end of my truck. It seemed like everyone I mentioned it to had a different solution. As it turns out, it was the hub assembly that I replaced that fixed the vibration.
For months, if I was driving short distances, everything was fine, but if I was driving for 30-40 minutes or more, ...if I hit a small or large bump, it would cause the whole cab to vibrate. ...Sometimes it would go away if you hit another bump, but not always??? ...but other times you could hit a bump and nothing happened! It was a little unpredictable at times.
From my own thoughts, and what people told me, it ranged from faulty cv joint, inner tie rod end, seized front axle, to worn sway bar bushings! I'm not saying none of these things if worn out wouldn't cause vibration, but it was a very time consuming process to get to the bottom of this.
So the purpose of this post is not to look for answers but to provide a possible solution for someone who may be trying to solve a similar mystery that I encountered.
Thanks for reading 8)
