Primosboy
- Feb 7, 2009
- 19
- Sacramento Ca.
- ford
- Engine Size
- 2.9 efi v6
My 87 STX is finaly on the road,and I've discovered an issue. It has this on and off lack of power and erratic idling. It will be idling fine and all the sudden start choking like it's gunnu die. After a couple minutes it will go back to normal for anywhere from 1-10 minutes,and then it starts choking again. The same while I'm driving. It will be running strong and then all the sudden it starts choking and won't have any power. At times I can pull off the road,shut the truck off,wait a minute and start it up again and it's fine,other times it will go back to normal on it's own. I've replaced the fuel filter twice and the fuel pump relay. I'm told it's most likely the in-tank fuel pump,but I can hear the pump prime when I turn the key. What's the deal??
