F-150 front coil springs
Twisted_Steel
Burlington, NC
302 HO
I have access to a 1986 F-150 that leaves for the scrap yard this weekend.
I need the springs to straighten up the tires since the truck originally came with a 4 banger and the tires are toed in bad at the top.
For those who have done this swap, what all do I need from the donor truck other than the springs and shocks?
17,838
SW Iowa
I would let them go, fullsize springs are way too stiff for an RBV.
New replacement springs are pretty cheap, I think my Explorer ones were around $60 for the pair a few years ago.
alwaysFlOoReD
5,095
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
^^^ While I agree in theory, sometimes you gotta make do.
Grab the J hooks and the washer-cone at the bottom. It's been a long time since I did this that I don't remember exactly what I did. I did go from one extreme to the other with the camber. This was on my b2 that I used as a snowplow. I looked at old pics and I went from 29" to 33" at the top of the fender opening. It looks like I grabbed the bottom bolt too. Use heat to get it out as the factory uses a thread locker. I don't really remember if I used the bolt. It also looks as if I drilled the center hole of a slightly concave washer, perhaps from a radius arm, big enough to fit over the hex part of the beam bolt. I ended up using a hose clamp to hold the top of the spring in place on one side, I can't remember why, perhaps I lost the J hook. I used the J on the other side. The springs don't fit into the upper part of the bucket very well, I twisted them to fit the best I could.
I'll see if I can load pics later.
Starting at post #20;
http://www.therangerstation.com/forums/showthread.php?t=98389
Twisted_Steel
Burlington, NC
302 HO
Thanks Guys,
I'm going to check into the new springs this evening.
