- May 23, 2014
- 167
- Kelowna BC
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- Solid Axle Swap 4x4
- Total Lift
- Around 6-7"
- Tire Size
- 38x15.5
Hey guys, Im looking into doing a leaf swap, but am not sure about a couple things. First off i have a 2008 Ranger FX4 with a 3 inch BL, Beltech shackles, stock leafs, stock 1.5 inch lift blocks, & a T bar crank to level.
As expected, my leafs have flattened out and ride like crap. But i am still happy with the height of the truck. My plan is to throw in some explorer leafs and remove the factory lift blocks to maintain the same ride height. So from what I have read, most people get 1.5-2 inches of lift from explorer leafs. So in theory, if I install the leafs and remove my factory blocks, I should be close to the same height, right?
My questions are:
Are my numbers correct in regards to amount of lift?
Are explorer leafs a bolt in application? (No relocating perches, same bushing sizes, etc.)
If so, which explorer leafs are my best option? (Year, Trim level, Body style)
If explorers are spring under axle and rangers are spring over, what happens with the centering pins on the leaf pack?
Can i reuse my stock u bolts without the lift blocks? Will they be too long?
Thanks in advance.
My questions are:
Thanks in advance.
