Expedition Oil filter relocation
Ramcharger90
1,708
N/A na
306, Bcam,
So I put a starter on an Expedition yesterday and noticed they come with a oil filter relocation kit from factory.
47734
Im sure this has been discussed before but maybe some worth rediscovering or adding to the tech section if it isn't already there. I might take a drive to the junk yard to grab one.
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
Under the front bumper?
Thats where my 97/98 was. Stupid location, smoked a deer with my 97 and had to be towed home.
Ramcharger90
1,708
N/A na
306, Bcam,
Talk to Ford home boy, I just thought it would be another option for guys to go to the jy and grab one. I put my oil filter here.
47735
Junglejoe
66
Columbia Missouri
6.0
Expedition had the 5.4 triton.. would that oil filter relocation fit a 302??
Ramcharger90
1,708
N/A na
306, Bcam,
Maybe I think the 4.6 and 5.0 use the same oil filter so the 5.4 should use the same. Worst case scenario you get the oil filter end from the jy and a L&L products engine side with an10 lines and fittings.
2drxploder
436
usa
ranger
347
lower
235 on 15s
what about the ford 90 degree block mount filter? will thry work on v8 swapped rangers?
the style that still mounts oil filter near block, just turns it 90 degrees
17,827
SW Iowa
4.6/5.4 use a FL-820S, metric threads. 302 uses the old FL1A which is standard threads
Your results may vary, I do not have room with mine. Steering box is all over it.
