exhaust manifold bolts
RANGERICK
15
Vista Ca.
1987 & 1989 B2
Ford Bronco II
stock
Be patient and use a torque wrench when called for.
I'm replacing the heads on my 87 2.9L V6 and I need new exhaust manifold bolts; complete set left/right. Anyone know where to get these buggers?
gaz
656
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
@RANGERICK ,
I always use Stage8 locking header bolts, I have read that several individuals replace the bolts with studs and nuts. I have a great fastener store near me that I would consider buying 12 grade 8's with washers or a set of stainless steel bolts, either way I would expect it to be less than $20 unless you decide on something like the Stage8's which are about $70 a set.
lil_Blue_Ford
6,131
Butler, PA, USSA
4.9L
Bolts are metric M8 I believe. Not sure there’s a kit or anything. You’re going to have 6 short and 6 long if I remember right, but I don’t know the exact measurements. Stainless would be nice, but you may have a hard time finding what you need without changing to headers
RANGERICK
15
Vista Ca.
1987 & 1989 B2
Ford Bronco II
stock
@RANGERICK ,
Gaz, I found a source but I need to confirm sizes before I buy them. This is what I got from Bronco Corral M8 1.25x75 (8), 1.25x50 (3), 1.25x 30 (1) Can anyone here confirm those sizes?
gaz
656
Wa, Bremerton 98310
The bolt set is a set of 12 fasteners which are all the same size;
it sounds like you are considering the Stage8 set, I recommend looking up the part number from SummitRacing.com for the engine you are using.
Stage8 part# for Ford 2.9l and OHV 4.0l is 6919.
