Ok, update on everything! Today I went to check everything that was mentioned in the previous comments.
It doesn’t appear that I have any kind of EGR system related things anywhere. The exhaust manifolds have no place for an EGR pipe, nor does the intake manifold.
Bringing up to temperature on cold startup it actually acted like it normally does when it hasn’t been idling high. It idled at just above 1000 rpm which is what it sits at with no prior issue. I took it on a test drive for 10 miles around town and when I returned home, I put it in park and the idle shot up again.
I unplugged the IAC and it dropped to about 800 - 900 and definitely wasn’t acting like it wanted to stall out UNTIL I sprayed carb cleaner directly into the air filter about where the MAF sits. It dropped to almost a stall for a few moments and then rose back up. I also unplugged and capped off the PCV valve from the intake and verified it wasn’t leaking from the fitting. Then I adjusted the throttle screw a few turns outward. I marked the original placement of it just in case.
Plugging the IAC back in after all that it held at about 1600rpm. I killed the engine and restarted it and yet again it was hard to start and when it did start, it ran all the way up to 3000rpm before dropping down to about 1800-2000.
Any ideas? I rechecked every vacuum fitting, around the manifold gaskets, and around the injector gaskets with carb cleaner and the only thing that caused it to change in rpm was spraying directly into the top of the air filter close to the MAF. It’s a cone air filter with no box and if I spray on the bottom side of the filter it doesn’t exhibit as much noticeable change as when I spray the top.
