electrical issues / 2002 Ranger
jwh f-100
PA
too small 3.0
I have a 10amp fuse that continues to blow. When it blows the air bag light comes on, the reverse lights do not work, the heater does not work, and it will not shift into over-drive.. Thoughts??
It is a 2002, 4x4, auto, excab, 4.0L
Thanks!!!!!
Earl43P
38
Farmington, Pa
Ford F250 4WD
First thing I'd do is disconnect the heater blower and see if the fuse stops blowing.
Then, inspect/replace the blower motor resistor block and its connector and possibly replace the blower itself.
Does the blower run in all speeds?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
It blows instantly or when you switch something on?
jwh f-100
PA
too small 3.0
Thanks for the replies guys.
It turns out it was a short in the column. I was helping a co-worker with this. He took it to a repair shop before I could try a few things..
