eec fuse blown 2x
leeboy
FORD
truck dies while driving. cranks but wont start.
after missing blown fuse first time.put on new coil pack, plugs, wires,
fuel filter. My nephew found 30. eec fuse blown . replaced it , started up and ran for 3-4 sec. and died, fuse blown.in my redneck wisdom i put in a 40 and it started up ran for 6-8 sec. fuse blown. so what is making fuse pop and where do i start.
cp2295
7
Washougal, wa
4.0L swap, 8.8 explorer axle, IFS front end
If you ain't first you're last
A short in the wire probably, check the wires running to the fuse and to the computer
cp2295
7
Washougal, wa
Make sure there's no frayed wires grounding out and check the grounds on the truck too
leeboy
FORD
update
thanks cp, im trying to isolate it, got as much connectors unplugged that i can reach and still blowing fuse with ignition on.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
is the truck an automatic?
leeboy
FORD
update
yes it is....i can actually hear the short if i just touch the fuse to the connector....its behind engine above tranny..still removing stuff from engine to get to it .
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Disconnect the connector to the transmission that controls the converter lock up
leeboy
FORD
update
long story short it was in tranny like squatch said. Thank you sir!!:beer:
since i had it apart looking for the short i heard {ya right}:icon_rofl:
i put on valve cover and upper manifold gasket. plugs,wires,coil pack.
anyhow got conecctor unhooked to tranny and it drove just fine, but of course no OD.
so now gotta find how to and whats all involved in that.. thanks all..
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I had this problem with my 91 a while back. Turned out when I changed the transmission filter a long time ago I got the overdrive solenoid wire pinched between the pan and the trans case when I put it back together. It finally rubbed through the gasket and the the wire shorted to the trans case.
