Early 90s F series project
OldJunk
Springfield OR
1984ish
2.8l V6 (Home Rebuild!) 2100 motorcraft carb
Getting bored looking at a project. got a low mile 460 from a 91 f 250, saw a 92 f 150 short bed 2wd w/ dead 302 , good e4od. besides bellhousing, motor mounts, exaust work and plumbing it would seem to be a plug and play. any thoughts for or against.
1badexplorer
Firefighter
4
Sutersville Pa
3.0, 501, 7.3psd, 351c, 351w
The bellhousing does not come off trans so you will need a new trans. you will also need a whole wiring harness, ecm, etc. However a haness from a 91 motor will not work with a 92 truck. It would be best to find a complete donor truck 92-96 style with a 460 and use all of the electronics off it
woodyedmiston
4
Texas
I saw your "old guy" post in another site - so, one old guy to another, this is a real ground pounding project if you choose to do it. I have a buddy who has a 64 F100 Short bed with a 460. The engine has a few improvements but the truck really scoots. He used a carb and avoided all the computer hassles. You can probably work out the wiring harness and transmission changes though. It is a kick in the butt to drive!
timster
Cedar Rapids, IA
the harness did change, however you can pull all the wiring out of the truck and rewire with the newer harness, or a even better option is to swap out your cabs. The 87-96 F series trucks are basically identical bodies, excluding the interior and the front clip, the front crumple zone/frame. the beds are the same, the cabs are basically the same. Its sorta like the 72 (or so) to 87 chevy trucks, which I have built several of and have a short bed I am planning on putting together this winter, the front clip changes then a few cosmetics in the cabs.
