Dust shield rubbing?
sgtsandman
Aircraft Fuel Tank Diver
12,650
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Your theory is the one I would go with.
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Well... a bent shock would do it. but that woud most likely cause a performance issue also... and fluid leakage.
It could also be a bent or mis-aligned dust cover. If it isn't leaking... try tweaking the dust cover a bit to clear the shock body.
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You can also cut off the metal dust cover and install a rubber shock boot.
4x4prepper
216
Atlanta
Upper rubber might be compressed too much and squished out. Maybe remove the top mount and place a 3/8 washer behind and put the shock back on, that might be enough to give it a small alignment.
