duratec's that came with 4.10s
jax4bangin
WESTMINSTER CA
2.3
if ur truck came stock with 4.10 gears, what rpm are u at @65 mph? in 5th gear or overdrive
fordboi415
rancho cucamonga california (socal)
3.0V6
That's going to depend on tire size and 5th gear ratio assuming its that same in every ranger/explorer 5spd but it should be anywhere from 2000-2500rpms
jax4bangin
WESTMINSTER CA
2.3
yea im jus curious to see wat the duratec's with 4.10 gears and stock tires crusing rpm is.. im plannin on puttin in some 4.56s in tomorrow along with my 30" tires and my actual ratio (according to the calculators in the tech library) will be 4 to 1 (4.10)
hmiwb
2.3
My 09 with manual trans and stock tires (225/70R15) turns 2750 @ 70 mph so I would figure its probably about 2500 @ 65 mph
jax4bangin
WESTMINSTER CA
2.3
u have the 4.10 rear end right?
m8r8j
blue oval
2.3 duratec
how do you tell what rear end you have???
hmiwb
2.3
Yes, I have the 4.10 rear gear
jax4bangin
WESTMINSTER CA
2.3
check the tag on ur differential cover.. its attached to the dif by one of the cover bolts
shudd say a letter or 2 and ur ratio number
