Duraspark No Start?
Bronco
:bawling:I have had a duraspark conversion done on my 84 bII for a year now and i am having problems now. I have installed a new distributor ,ignition module and coil. I have ohm tested the wires going to the distributor to make sure they were not broke. I get a real bright green light flashing when i hold the distributor in my hand and spin the rotor, but when the distributor touches the engine block to ground the light dims down to almost nothing and no flash. Can someone explain what each wire color does on the ignition module up to the distributor? I need your input really BAD!!!!!! Please HELP!!! If you would rather talk to me on phone i will gladly call you.
almostclueless
A bright green light? Are you talking about the spark or some test light?
To answer your wire question, the orange and black wires connect the pickup coil to the module to trigger it. The black wire ensures the system gets a good engine ground thru the body of the distributor.
Judging by your description, it sounds like the pickup coil is grounding out. If there is any real continuity between the orange or purple wire of the pickup to the body of the distributor (with the module unplugged from it), the pickup coil is shorted and the system won't work.
It's not real difficult to change the pickup coil, but the cost of a decent one is potentially more than picking up a used distributor.
Bronco
No start?
I ended up replacing the pickup coil and ignition module and it runs again, we will see for how long.
budro
Coils
Make sure you are not still using the factory 2.8 coil. Also make sure you are not using a points coil. If your coil has threaded lugs on it to connect wires its a points coil. The coil you need is from like a 80 Ford F-150 pickup. It will have round terminals on it that require a horshoe shaped harness plug to connect up to it. Or I have seen people just slide spade connectors on the terminals. I have fried numerous ignition boxes till finding out this info. What happens is that the coils can't take the constant 12v when you have the key on without the engine running. In about 5 mins the coils are so hot you cant touch and the ignition boxes are even hotter. Pays to get the lifetime warranty DS2 box. Also you could try a ballast resistor. Mine didnt have one so I put one in-line with the coil but then the coil wouldnt fire. There isnt one already in the factory harness so who knows.
