Dual caliper on explorer 8.8
Anthony B22
03873
ford ranger 2wd
I have an explorer 8.8 and i want to run a hydro in it, but i cannot find a dual caliper bracket anywhere, i saw some guy cut and welded 2 of the caliper brackets together to achieve this goal but i am a novice metal fabricator and don’t trust that everything would line up, aftermarket makes a bunch of options for the sn95, does anybody know it i can slap sn95 brakes on an explorer rear? they are both 8.8s and based on the research i’ve been trying to do it seems they’ll fit but wanting to hear anyone’s advise/experience
alwaysFlOoReD
5,147
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Are you asking about dual pistons? I dont know if there would be enough room for dual calipers.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
the explorer calipers should be ok.
they have bigger pistons so you may need to adjust.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
they are totally different calipers
snoranger
Professional money waster
ASE Certified Tech
13,729
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I assume this is the homemade one you saw...
72392
Try this one... it’s a little pricey:
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
is that to hook one set to drift brakes?
alwaysFlOoReD
5,147
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Well.... I guess I need to get out in the world a bit more...
don4331
1,355
Calgary, AB
5.3
In answer to your original question - the SN95 uses small axles (1.4" bearing surface), and the small caliper mounts, while the Explorer uses medium axles (1.620" bearing surface with the large caliper mount and the newer F-150s use large axles (1.705" bearing surface). So, no, you can't slap SN95 brakes on an Explorer axle.
But I think @snoranger provided the solution you were looking for (if not at the price point you were hoping for).
snoranger
ASE Certified Tech
13,729
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I probably wouldn’t spend $1300 on the setup I posted... I’d sooner make the homemade system from the first pic I posted.
He cut both a left and right side caliper bracket in half, bolted them on the same axle flange, then welded them together.
72575
don4331
1,355
Calgary, AB
5.3
But then you don't have the pricey Winwood calipers :icon_twisted:
I hadn't noticed that the front and rear caliper brackets weren't mirrors before. But then I can't weld cast worth $#!+, so I definitely wouldn't mess with it on brakes. But it does give me some ideas for my project.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
3/8 plate and some drill and grinder work ....run the jp6 calipers and a set of stang calipers for parking brakes.
so you have parking brakes and drift brakes
Easy to make.
alwaysFlOoReD
5,147
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Sooo....
What the hell are jp6 calipers?
snoranger
ASE Certified Tech
13,729
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
alwaysFlOoReD
5,147
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
