Drive Shaft 911
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
I am switching my transfer case and I took out the 4 drive shaft bolts on the output of the bw1354, but the driveshaft is stuck to the transfer case. Please Help!
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
gentley tap the flange on the d shaft. it should come loose.
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
if gently doesnt work, get more aggressive. the only thing holding it there is rust.
MAKG
19
California central coast
It may just need to be compressed a little bit.
Thread one bolt in a little bit by hand (to prevent concussion) and remove the rear bolts. Then remove the last bolt with one hand supporting the driveshaft. The whole driveshaft is easier to remove that way. But it will have a tendency to FALL out if you remove all the bolts without a hand on it....
It will be in the way if you just disconnect the front and let it hang.
