Does anything like the shiftster exist?
fknrngr
California
I recently bought a 98 ranger 4x4 and the 4wd system is somewhat problematic. It works but will sometimes get stuck in 4wd. I already converted it to manual locking hubs and I really would rather have something on the transfer case that I can turn to shift it in and out of 4hi and 4lo, just so I actually know that it goes into 4wd. If nothing like that exists anymore is there something I can make that does the job? Thanks
franklin2
1,767
Virginia
Bronco II
You can do what I did on my 1986. I bought this switch.
I bought a 30 amp circuit breaker and mounted it to the battery + terminal. Ran two wires from the circuit breaker and the - of the battery into the cab to the new switch. Coming off the switch I ran two more wires out of the cab and down to the transfer case. I snipped the two motor wires and wired my two new wires to the motor.
If you look at the switch, you will see a "X" on the back of the switch. This switch is setup to forward and reverse a dc motor, which the transfer case motor is. So when you move the switch, the transfer case motor will go one direction or the other, engaging the different transfer case modes.
Some comments about the above modification; It works very good compared to the computer system that may or may not work when you need it. You can count on this simple system to always work if your motor is good. But;
They must have supplied the motor originally with something less than 12v. With this modification the motor seems to move very quickly. So it is best to "bump" the switch when moving the motor.
You are in the dark sort of, moving the motor and feeling what gear the transfer case is in. Sometimes you might get it on the edge and it will grind until you bump it a little more or bump it back to fully engage the proper mode.
A important note; YOU MUST BE STOPPED TO USE THIS MODIFICATION. If you have your wits about you, and your hubs are already locked in, you could shift it on the fly, but there is a danger of moving too far and engaging 4 low. So I would err on the side of caution and stop while using the switch. Also, I never had little kids in the my truck by themselves. I can see you driving down the road and a child playing with the switch or accidentally knocking it while driving, which would not be a good thing. If you were afraid of this situation you might could use another lockout switch somewhere so the direction switch would not work.
franklin2
1,767
Virginia
Bronco II
What I did to help the situation out a little bit was to wire up the lights in the dash to see what mode I was in. The switch and all the other wires are still going to the motor, you are not using them though. They still go up to the 4x4 computer module, my module was under a plate at the top of the dash. All the mode lights for the 4x4 are also going to the computer module. And there is 12v going up there too. Snipping more wires, I took the 12v and hooked it to the common going to the motor rotary switch, and then found the proper wires for each mode and directly wired them to the dash lights. So when I bumped the motor to a certain mode, the proper 4x4 mode light would light up, and that helped me find where I was at when bumping the switch.
It's more wiring, you might want to try using it blind and see how that works. If you need help wiring up the lights I can try to walk you through it.
00t444e
217
Southern OH
Ranger ext cab
Convert it to a manual shift transfer case, that is what I am doing.
