- Jan 28, 2017
- 44
- Leicester, NC
- Ford
- Engine Type
- V8
- Engine Size
- 302
- 2WD / 4WD
- 2WD
- Tire Size
- 205/60R15 & 225/60R15
1987 Ranger,2WD, 302, Toploader 4-speed. I've had two different 302s in the truck but both times it was removed and installed with the bellhousing already bolted up to the block. I never thought about the need for removing the bellhousing under the truck. Now I've blown the trans and need to change the clutch also. I have another 4-speed and clutch kit. 4 bolts and the old Toploader came out but the bellhousing won't fit. It gets wedged between the firewall, headers and the RA crossmember. Can I just cut the center of it out? I've owned and still own a lot of Bullnose full size trucks and they don't have that crossmember. Can I cut it and bolt a piece of steel between the frame rails? Granted I'll lose the front sway bar but I'm running out of patience and options. It's either cut it or pray the body mounts come loose to jack the cab up a little. Any input on the situation?
