Do i have a a 2.0 or 2.3??? 1984
rangerdewd84
2.3
Ok so a long time ago, before I got the truck, someone did an engine swap. I don't know if they put the original engine back in ( which according to the VIN number would be a 2.0l) or put in a 2.3. I researched the casting number on the block below the exhaust manifold and a few links came up on google. One of the first ones was a guy on one of those "ask an expert" sites who had the exact same number and the expert said 2.3l 140 CID, ect. Now when i thought i had a 2.3 and not a 2.0l like i had originally thought, I made sure the parts i had been buying were right. The spark plugs were different so i put in 2.3l spark plugs. NOW, yesterday i took off the valve cover to have a look around and i wrote down the casting numbers on the cylinder head and it said "E67E" "A8" "D06". I did some looking around and the "E67E" casting number seems to come up with 2.0l heads. The number on the block that led me to believe it was a 2.3 was "E59E-6015-BA. I'm really frustrated and confused :<
SenorNoob
569
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
2.0 head on a 2.3 block? Is that even possible?
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Yes, they are the same bolt pattern but the pistons are slightly bigger on the 2.3...and if you use the 2.0 head gasket you will see the difference right away...but use the 2.3 head gasket regardless when the time comes.
As for the confusion to the OP...what are you trying or wanting to do? If it's just identify what you have then you are making this more difficult and putting a higher level of importance on this knowledge than you will ever need.
So...what, other than identify the engine, do you need or want?
EDIT: Just for reference sake, lets go back to the plant where they made and assembled these engines...so Harry, the builder, is making 2.0 engines and happily cranks out a few a day for so many days...one day Harry looks in his parts bin and finds he has no blocks left so he calls up supply and asks them to send another skid or two his way...the parts supply finds out they are also out of the 2.0 blocks but seem to have excess 2.3 blocks...so they send Harry a skid or two of the 2.3 blocks and some pistons to finish them with since they use the same crank and other parts...
Harry quits the next day and Sam takes his place...Sam's house is blue but Harry was living in a red house so the engines will still be the same...just have different sized pistons...
rangerdewd84
2.3
What I want to do is ensure that im buying the right parts for my truck....
cody93
42
Duluth GA
FORD
only difference between 2.0 and 2.3 blocks is bore size, shouldnt matter if your not dealing with piston and rings.. i had a 2.3 that ran a 2.0 head because all i could find was a 2.0 round port carb intake..
