dana 35 front diff lock
ChristineTheRedRanger
Doylestown, PA
FordRanger Edge
Hi everyone. I have an 01 ranger edge named christine I use for wheeling. 4L SOHC, automatic trans, 8.8 rear, dana 35 front, 4.10 gear ratio, electronically actuated 4x4.
I've starting shopping around for diff locker to install in the front. I don't want to "lincoln lock" it, but I also don't want to spend a ton of money either. She's a woods beater, not a competition truck. I found a locker on amazon (the Powertrax 2311-LR Lock-Right (Dana 35)). Description says for 27 spline axles and for 1993 and later models. Amazon says it fits my ranger, but I want to make sure before buying. I did read in one of the threads that the front axles are 27 spline for my year range, so I'm lead to believe that it will work.
What are your thoughts?
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
It would be better to have a selectable locker or LSD for the front axle. A locker can make it difficult to turn. Aside from that I've used the lunchbox lockers before and was pleased with the operation and cost.
ericbphoto
Overlander in development
16,663
Wellford, SC
6"
I agree that selectable is better. But I'm not rich. So I run an Aussie locker in mine which is similar (same principle) as the lock-rite. It does make it more difficult to turn sharp in 4wd. But all that means is that sometimes you have to do a 3 point or 4 point turn to get around sharp, tight switch-backs on trails. For the money, it's great and in 2wd, it has no affect on turning. So road manners are fine.
I have Aussies front and rear in my truck and the performance surprises me all the time. I like them.
Doylestown, PA
FordRanger Edge
Do you have a website link to the front and rear lockers you mentioned?
ericbphoto
16,663
Wellford, SC
6"
sgtsandman
Aircraft Fuel Tank Diver
12,707
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I believe the 2001 has the Dana 35 SLA. They aren't as strong as the TTB Dana 35 axles on the earlier generation Rangers because of the half shafts. If you decide to go ahead with a front locker, tread lightly and make sure you bring tools and spare half shafts in case you break one. Me personally, I wouldn't go with more than a limited slip in a Dana 35 SLA.
