cbxer55
- Oct 9, 2009
- Reaction score
- 767
- Location
- Midwest City, Oklahoma
- Make / Model
- Ford
- Engine Size
- 3.0
- Automatic
As many here know, I purchased a set of ancient Cragar Mag Master rims from another member here. They appear to have been manufactured in 1974, as there is some number stamped on the back, most of which is goblety-gook, but the last two digits are 74. They were only made form 74 to 78. Another member here apparently contacted Cragar (I didn't know they were still around), and they have no recollection of making these rims. Also stamped on the back is Made In Mexico, in 1974 (Gee, whodathunkit?).
The rims have slotted holes for the studs. And they are installed with washers with an offset hole, for the 5 x 4.5 and 5 x 5 spacing. Another washer set with centered holes covers 5 x 4.75. They're kind of finnicky to install. I found it easiest to start with the lowest hole, as this keeps the washer in proper orientation, with the meat of the washer hanging down and the hole closest to the center. Once I got them installed, I drove it. Perfectly smooth, no vibration at all.
The front rims are 14 x 7. The rears are 14 x 8.5. The front tires are Mastercraft Avenger GT's in 215/70-14. The rears are BF Goodrich TA Radials, in 245/60-14. They're like .40 shorter than the tires I had on it before, and along with the 4.10 gears in the axle, are causing a 10% higher speedometer and odometer reading. I can live with it. For now leastways.
When I first got these rims, they were pretty tatty. They had some kind of clear coat on them that had deteriorated with age. Took me almost a month, with various grades of emery cloth, from 180 to 400, then course red scotchbrite, and finally fine green scotchbrite. and followed with two coats of Turtle Was Super Hard Shell. That is what you see here.
The rims came with four smooth center caps, and one original Cragar center cap, that is pretty tatty. My intention is to replace the caps with knock off spinners, with CRAGAR center decals. And copying my friends 2018 Shelby AC Cobra (registered as a 1965), the spinners will be safety wired, for appearance sake only. LOL!!
