Cowl induction hood
5tonford
West middlesex pa
We are restoring a 1987 ranger for my boy and he wants a cowl hood for it. Does anybody know of a steel scoop we can put onto his hood or anybody that makes cowl hoods for these trucks? Thank you
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
You could just make your own by cutting two lines in the hood, raising it up and filling in with metal.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Summit, jegs, etc. Have a billion different scoops.
cbxer55
767
Midwest City, Oklahoma
Even CARiD does as well. They may even have a hood for it. They have in the past. Fiberglass though.
Uncle Gump
Token Old Guy
13,458
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I had a bookmark before my hard drive crashed... someone was making a cowl induction hood for a first gen. But I can't remember who it was.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I remember LMC truck having one but I don’t remember what generation it was for. They might be worth a look.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
If the back of the scoop is open engine compartment air will be drawn in through the vents.
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Uncle Gump
Token Old Guy
13,458
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
cbxer55
767
Actually, cowl type hoods act like heat extractors. Even though the base of the window is a high pressure area, I guarantee the hot air coming out of the radiator, being pushed by forward movement, is higher pressure than the base of the window. I've tested it using the streamer method. Only time I've had a cowl hood that actually worked like they're supposed to was on a Firebird years ago. Had a Z28 scoop on the hood. When first installed, the streamers always flowed up the windshield. After fashioning a pan out of sheet metal that sat on top of the carburetor, with a velocity stack on top of that, and one inch thick foam around the edges of the pan. then it worked as an intake. Worked so well, I had to reinforce the scoop, as it kept puffing up at high speeds. Almost tore it off the hood.
Wish someone made a nice hood for the 98-00 models.
gaz
656
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
5tonFord,
I used an old Mach1 Mustang hood. I cut out the hood scoops and grafted them into a 1st Gen Ranger's hood. Because of the length differences, the scoops are raised past the rear hood line, as in a aft cowl induction system.
