- Aug 31, 2021
- 974
- Roanoke VA
- 1997 and 1999
- XLT 4x4 & B3000
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L in XLT, 3.0L in B3000
- 2WD / 4WD
- 4WD
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
Can't find good video or anything on this. Searched posts.
Do I need to drain system first? If this isn't high spot coolant will run out.
I've done them before on other vehicles, looks like take off radiator hose if you want then two bolts, take out old, put new, I assume with new gasket that should come with it(?). They told me here use 190-195F thermostat.
I'm wondering am I missing anything, and, would this be a good time to flush the system because the coolant looks kind of yucky. If I want to flush it then probably I should do it first but I guess it doesn't matter. I assume there is a drain on the bottom of the radiator?
Sure would appreciate any help.
