Thrashingrage
- Aug 3, 2012
- 0
- Ford
Hey guys,
So, as usual, I've got a couple of questions about my '90 Bronco II. First of all, today I found a small leak in the passenger side of the radiator that looks to be coming from where the plastic and metal meet. I have checked the upper hose and the petcock, and neither one of them is the culprit. As far as I can tell, this leak has made a small, maybe 3" in diameter, dark spot on the parking lot outside of my dorm over the last 3 days.
The second coolant leak in question has been going on for a little over a month, possibly even longer, and seems to be coming from the timing cover gasket, about midway up the height of the cover on the driver's side. I did a search here and saw that the 3.0s have this problem quite a lot, but didn't see anything with the 2.9s. I looked carefully at both the driver's side head gasket and the lower intake manifold gasket, and neither one of them appear to be damaged or leaking. I put a clean shop towel on the block just above the timing cover and am going to check every day to see if any coolant is leaking from the intake manifold gasket and running down the side of the front cover.
So, as far as these two leaks go, I am wondering what my best bet is in terms of fixing them. At the moment, I am in college full-time and drive about 120 miles a week to go home and back on the weekends. Friday, Saturday, and Sunday are really the only days that I have to work on the truck in the peace and quiet of my own garage as opposed to crawling around on the asphalt in the parking lot. I really do not like putting off repairs, especially when the cooling system is involved. However, even if I can come up with the money for a new radiator, it will be at least two weeks before I can put it in, as I will have to get one shipped from Bronco Graveyard in the interest of not ending up with some cheap, shitty radiator. As far as pulling the timing cover goes, I won't have time to do that until my Thanksgiving break the week of November 16th. If these two continue to leak minimally, will they last that long? Ideally, I would like to just pull the engine this summer, as I'm planning to do all of the body work and put a new clutch in, so I would rather just do everything at once. At this point though, that seems like a long shot. My biggest concerns are the possibility of the radiator going and the timing cover leak letting coolant in the oil. How long will a leaking 2.9 radiator generally last before it gets dramatically worse? Also, is there a freeze plug behind the timing cover? I actually just changed the oil about a week and a half ago and put some Marvel Mystery oil in with the Valvoline Max Life for good measure. I checked the oil today and did not see any 'milkiness' - still looks damn near new.
Anyway, thanks to anyone who read through this long post. Even 276,000 miles on the road, the Little Bronco still starts every time, runs great, drives great, and stays cool, and I hope we can keep driving for another 200,000 miles.
Thanks a lot,
Josh
Thanks a lot,
Josh
