Coolant leak between engine and transmission
rickyrockrat
San Jose
3.0L V6
Hello,
I have a 2000 Ford ranger 3.0L manual. There is coolant pooling under the truck and it appears to be coming from between the engine and transmission. Best guess is a leaking freeze plug. Is this reasonable? If so, what is it going to take to fix it and is this something that can be done in the driveway without yanking the motor and tranny out of the truck.
Thanks.
Rick:icon_confused:
martin
26
St Bruno, Quebec
1991
Are you sure it's not a leaking heater core, the pool on the ground would be in a similar place?
oldfordman
If it were a leaking heater core, chances are there would be fluid on the floor on the passenger side, and you would smell/taste the antifreeze, especially when you use the defrosters. As memory serves, there are 2 or 3 freeze out plugs on the back of the block. And, sorry to say, you need to pull the trans or engine to get to them. A real PIA, so confirm that is the problem before you get that deep into the project. On the 3.0, there is also another hidden one behind the P/S pump. Many years ago, the manufacturers used brass plugs that did not corrode and leak after only 8 years or so. But they had to save a buck or two per car, and started using steel plugs, which will corrode, especially if the antifreeze is not changed on a routine basis. So, the 2 dollar saving puts a much larger expense/problem onto us poor folk who try to keep our vehicles a long time. FYI- Freeze plugs are not there to prevent the block from freezing and cracking, they are from the casting process)
TomB1269
Capital District NY
2002, 2005, & 2
All Fords
3.0L/4.2L/5.4L3V
There are 2 on the back of the block, take a look at the 3.0 rebuild page in the Tech library and you will see right were they are.
oldfordman
Another thing to check on- the 3.0 engine also has a freeze out plug on the end of the heads. On the left side (driver's side) it is in the front, behind the P/S pump bracket. But on the right, passsenger side, it is in the back in front of the firewall. If that one is leaking, it could be following down along the back of the engine, so it looks like it is coming from between the engine and trans. If you use an inspection mirror, you can see it. If it is leakiing, it is possible to change w/o removing the head, but it's a tight fit. There is not enough room to tap a new back into place, but my local mechanic says he replaces them with a good metal replacement plug that has an expansion bolt in it- NOT the cheap rubber versions. There is just enough room back there to swing a small wrench and tighten it up.
rickyrockrat
San Jose
3.0L V6
Thanks
Thanks for the replies. I have been on the road at meetings for a while. For some reason the problem has gone away and not reappeared. The fluid wasn't oil and I am not sure now exactly what the hell it was at this point. I pressurized the cooling system for about two hours to 16 psi and nothing showed up and if it shows up again I will try that again. Weird.
