Code P0455
tchef
Hello, I'm new here. I have a 2002 Ranger XLT with a dual overhead cam 4 cylinder engine, manual trans. I have searched this forum for other people with this problem and found basic info but I need a little more.
So far I have replaced the fuel cap, and the purge control valve that is located under the hood by the brake cylinder. I have inspected all the hoses and can't find any holes. I have cleared the code each time and it comes back in a couple of days. I have also removed the charcoal canister from under the spare tire and inspected it. Didn't find any cracks or anything wrong. I tested the coil in the solenoid valve and it seemed fine. Didn't test the valve though.
Any Ideas? I have to get this fixed, my inspection notice came this week as well.
Thanks.:dunno:
tchef
Ok, so here is the update. I pulled the Charcoal canister out from under the spare tire and removed the solenoid valve and tested it on the battery. Nothing happened. It seems to be stuck open. I have ordered a new one from the Ford dealer. I'll give another update when I have installed it.
SMTGREG
MGB
2.3 Lima
The valve you are referring to is the canister vent valve. The valve is normally open without power and closes with power. These valves do get dirty and stick.
You probably would have spent less having a dealer diag the problem ($79.95 at our shop) then replacing only the bad part or hose.
