2.3L ('83-'97) Code 452
davidmichaeldore
9
Port Neches, TX
Ford ranger
typically the difference between an $8 and a $20 haircut is way more than $12
Please help
Vindictus
330
NewBrunswick Canada
ReMan 4.0 SOHC
P0452 - Evaporative Emission System Pressure Sensor/Switch Low Description: The powertrain control module (PCM) monitors the evaporative emission (EVAP) control system fuel tank pressure (FTP) sensor input signal to the PCM. The test fails when the signal average drops below a minimum allowable calibrated parameter. Possible Causes: Contamination internal to the FTP sensor connector FTP circuit short to GND or SIG RTN Damaged FTP sensor
