Code 41 and 88. what do they mean?
a-5 freak
23
Titusville, FL
2.3
i got a code 41 and a 88 while doing a diagnostic using the CEL. I HAVE checked the tech library and code 41 does not apply to the cel test and 88 is a combination of like 5 different things.
Wicked_Sludge
43
Westport, WA
3-point-GO
how does 41 not apply to a self test? the truck either is or was at some point running lean.
for code 88, you dont have a choke or carb...so we can rule out choke relay or throttle kicker. rangers dont have e-fans so its not that. so its either a transmission code or a spout connector code. if you have a 5 speed then that narrows that down.
RobbieD
2.9l Mafia
3,466
Georgia
The diagnostic codes can vary somewhat according to year, and driveline application. This has tripped me up before.
I've got the Ford 1991 Engine/Emissions Diagnostic manual; for the truck 2.3L engine it lists a code 88 as "Loss of Dual Plug Input control". And, it does list the code 41 as "HEGO sensor circuit indicates system lean".
The 88 is shown as a continuous memory code (KOEO), and 41 as an engine running code (KOER).
Hope this helps, and good luck.
a-5 freak
23
Titusville, FL
2.3
That does help very much thank you :D
And i have a 4 w/ od
